Problem with TFA reaction and separation
Posted: Thu Jul 28, 2011 4:19 am
I prepared tripeptide Boc-Pro-Pro-phe-OBn, then I did hydrogenolysis to deprotect OBn than I ran Normal phase column and I saw quite good separation in the column with small impurities. Then I ran TFA reaction to deprotect Boc group, during the reaction I checked with TLC and it looks single spot with little more polar than the starting material. When I tried to rotavap the reaction and washed with ether and finally After TLC I found the compound becomes more polar and it has more than one spots. It moves slowly in 90% Methanol in DCM. the reaction mixture turned yellow when I stopped the reaction. Although I purified the starting material but I got more than one spots. Strange!!! Can anyone suggest me why it happened??
Did I run over reaction? I ran about 8 hours.
What are possible side reactions?
is there any way to separate tripeptides in normal phase silica gel.
Thank you.
Thank you.
