Aspartame by Ph.Eur.
Posted: Mon Jul 25, 2011 9:50 am
Hi everyone. I'm having trouble analysing related substances of aspartame by Ph.Eur. First of all, I'm wondering if anyone else have had trouble with this, and how you ended up solving it?
The problem I'm facing is that the references seem to elute at the same time as the injectionpeak/voidpeak(or what do you call it?) or at the same time as another reference (B), L-phenylalanine (from Sigma-Aldrich). However, we are not certain of this, it might also be so that one of the references (D) have been decomposed. The reference is L-aspartyl-L-phenylalanine from Aldrich, but is it probable that it could have decomposed? It was first used in august 2008, so it is quite old, but still.
I was thinking it would be easy to check this by analysing them separately, but I don't seem to get any peaks from these in the chromatogram, even though I have been getting a peak for reference B earlier. This makes me believe that the reference (D) has been decomposed.
It's very strange, since the retentions times also seem to change quite a bit between difference sequence runs.
I have tried two different LC-systems (Both Shimadzu), three different columns (MZ analytical perfect sil C18 250x4,6mmx5um; Phenomenex Gemini C18 250x4,6mmx5um; Supelco Ascentis C18 250x4,6mmx5um) with one of them having been used succesfully before (the Phenomenex column) and I've mixed several new mobile phases. None of this have worked and from what we know I'm doing exactly the same as the analyst who did this analysis before and succeded with it. The only thing different is that I'm not using the same LC, however they are almost the same in components. Also, I dont get the same retention times for all references as the previous analyst received.
If anyone has any ideas, it would be very welcome!
