Relative retention of peptides in SCX-- revisited
Posted: Thu Jul 21, 2011 1:41 am
I've been searching for a rational basis for predicting relative retention of peptides at different pH in SCX, when I encountered this interesting paper:
Journal of Chromatography A, 724 (1996) 137-145
They use a column (called "hyper D- which I am unfamiliar with) claimed to be packed with highly hydrophilic cation exchange material, and, in short, found a linear relationship between retention time and NC*B/ln(N) (NC= net charge, B= basic residues, N= total number of amino acids). Granted, only short peptides were used, however, seems not many have hitched their wagon to this simplified "rule of thumb" algorithm for predicting retention. Is this because charge density is a non-issue, or rather, retention in SCX is far, far more complicated than net charge/charge density?
Andy Alpert published a paper in Anal Chem demonstrating peptide orientation effects in ion exchange HPLC: Anal. Chem., 2010, 82 (12), pp 5253–5259.
If I understand, orientation effects become less pronounced in larger, multiply-charged peptides? Beyond approx what MW does orientation play less of a role and over-all charge of the peptide become more influential in retention?
Secondly,
MeCN content in the mobile phase causes some interesting effects. I suppose this could partially be related to altering the structure of the peptide such that its contact region with the support is changed. Additionally, since MeCN changes the pKa of AA side chains, peptides that have the same net charge (calculated from aqueous pKa values) may not have the same net charge in 50% MeCN. Is this partially a reason for the selectivity differences observed upon addition of MeCN?
Secondly,
