Purification Problem: Amine-pyrimidine
Posted: Wed Jul 20, 2011 2:42 pm
I have problems when I isolute amine-pyrimidine compounds.
I use a C18 column (Gemini) with some mobile phases:
- Acid: 0,1% Formic Acid with a mixture of MeCN-MeOH
- Basic: 65mM Amonium Bicarbonate or 25 mM Amonium Acetate with a mixture of MeCN-MeOH.
if I use an acid phase, that compounds had formylated
if I use a basic phase, we have lost of amount, and we think that the product breaks down.
I don`t know if I have to use an other column (like a NH2) or another mobile phase with a high pH like NaOH or similar.
What do you think about this problem?
Thanks a lot
Thanks a lot
