Py-GC/MS and split ratio
Posted: Mon Jul 18, 2011 4:11 pm
I work with a Pyrolysis-GC/MS system. I use polystyrene as standard.
I can observe on the pyrogram styrene monomer(major peak), dimer and trimer.
Pyrolysis temperature has an influence on percentage of dimer and trimer. At 750°c I have less trimer than dimer.
Currently my GC method use a split ratio 30:1; but when I use a split ratio 50:1, trimer peak is higher than dimer.
I don't understand how split ratio can have an effect on high boiling compounds? Is it specific to the Py-GC/MS system?
Anyone have an explanation?
Thanks!
Damien
Thanks!
Damien
