Sample prep for HPLC
Posted: Mon Jul 18, 2011 3:17 pm
I have Agilent 1200 fitted with RID and Hi- Plex H column. I am going to analyze spent media containing organic acids (Acetic Acid and Lactic Acid). Spent media also has salts like NaCl (15g/L), MgCl2 (2g/L) and 20mg of KI and KBr. Can I inject the sample directly after centrifugation and filteration? Will these salts interfere with analysis or damage the column? If any sample pre-treatment is required to remove these salts then which technique will be the best to remove salts leaving organic acid in it with good recovery?
Sorry I asked too many questions.
Thanks for your help
