Converting IEX mobile phase to MS compatible
Posted: Fri Mar 25, 2005 10:01 pm
I would like to analyze fractions from an anion exchange separation by Maldi MS, however the samples are salty.
Mobile phase: 10mM Phosphate, pH6.5 with a 1M NaCl elution gradient. I need to either de-salt or change the MP to an MS compatible.
I have run pH studies on my protein and the best separation is approx. pH6.5 with all peaks eluting at <0.2M NaCl.
I could probably switch to Ammonium bicarb (pKa 6.3), but what can I use in place of the NaCl to elute from the An-IEX column that is MS compatible?
