high pressure and pressure fluctuations
Posted: Mon Jul 11, 2011 4:43 am
hi all,
I am a fairly to the Liquid chromatography world so please bare with me. I have a Shimadzu analyical system that I am running with a polymer column. Recently, I received a high pressure warning and the column started leaking. i have been trying to unclog the column but that is not working. It is currently running at 4300 psi and it fluctation about + or - 40 psi when I am pumping at 0.5 mL/min. I then bypassed the column and the pressure drops to 75psi but still fluctuations like I stated earlier. I thing that the system was running without the deagasser on for few hours which could be part of the problem. Also, I had used a buffer that may have precipitated on to the column. What can I do to save my column?? Please help!!!
