decreasing signails
Posted: Sat Jul 09, 2011 7:53 pm
I am having problem with the reproducibility of LC/MS signals. I use API 5500. I analyze the stability of small drug molecules (MW 200-1000 dalton) in blood or plasma after incubation at 37C for a period of time. The sample was prepared by quenching 20ul blood or plasma using 600ul mixture of Acetonitrile and methanol (50:50). After centrifugation at 4000 rpm for 25 minutes, 70ul supernatant was removed and mixed with 210ul water. Then the sample is ready for injection on LC/MS/MS.
For most of the compounds, I got good results. However, some compounds have bad reproduciabilities. When I repeat 15 injections from the same blood or plasma samples, I see decreasing trend in the MS responses. Can anyone tell me what can be the possible reasons? I know it can be due to matrix effect. Can it be due to dirty MS source? Thanks in advance.
