Volatile acids in manure
Posted: Thu Jul 07, 2011 6:50 am
I am currently trying to analyse VFA (volatile fatty acids) from manure samples (very glamourous). I have a free acid mix which I acidify to pH2 and extract with chloroform, then do a 2ul injection with a 13:1 split onto a deactivated wax column. Chromatography for standards is fine.
However when prepping samples the manure is suspended in water, acidifed and then centrifuged. The supernatant is passed through a 0.45um syringe filter into the chloroform, at which point a gel forms (possibly proteins?).
Does anyone have experience of this sort of testing?
One option is to use water injections (ie skip the chloroform extraction) but that would limit my injection volume to 0.5ul due to flashback, and I'm not wild about putting any water through the FID.
Thoughts?
Mike
Thoughts?
Mike
