Interference Peaks
Posted: Wed Mar 23, 2005 8:54 pm
Hi all
I am working on a related compounds method using xterra column RP8 3.5 um : MP is ammonium bicarbonate buffer10mM pH10 and ACN gradient. When i condition the column i see an interference peak comes at 50:50 buffer: ACN; This interferes with my impurites. i couldn't get rid of the peak. It is present in water. i used high purity water. it is still there. If i do only 50:50 isocratic i dont see that peak. my gradient starts 95:5(buffer:ACN) stays for 5 mins. goes to 50:50 in 20 mins. i need this gradient for separation of 7 impurities in the method.
can some body help me with this ( i don't want to develop a method around an interference peak)
Wavelength used is 230; present is all wavelengths
thanks
thanks
