Is there any method to determine Dimethylamine by TLC???
Posted: Wed Jul 06, 2011 4:36 pm
by vishnu
Is there any method to determine dimethylamine by TLC???
What are the conditions and what visualization agent can i use?
Re: Is there any method to determine Dimethylamine by TLC???
Posted: Thu Jul 07, 2011 5:54 pm
by tom jupille
dimethylamine is sufficiently volatile that it would not be a good candidate for direct TLC. Best approach would be to make a fluorescent derivative with something like NBD-chloride and run that.
Posted: Fri Jul 08, 2011 1:37 am
by vishnu
Thanks for the comment.
Can i do anything else to get that???
Posted: Fri Jul 08, 2011 12:39 pm
by vishnu
I am getting an impurity related to metformin named n-methylmethamine, which is nothing but DMA, i cant say this as volatile. i have to get spot in TLC for this. i tried almost all method for this. can anyone suggest anything related to that???
Thanks in advance
Posted: Fri Jul 08, 2011 3:43 pm
by HW Mueller
vishnu, do you have a reference to N-methylmethamine, there seems to be some confusion here.
Definatly, dimethylamine is quite volatile, I can imagine that one would need an acidic, nonvolatile mobile phase to hold
(CH3)2NH2+ on the plate, maybe??
Posted: Mon Jul 11, 2011 12:44 pm
by vishnu
i am using water acetic acid and butanol combination. i dont have a reference standard.
is there any method to identify DMA by tlc???
Posted: Mon Jul 11, 2011 3:34 pm
by tom jupille
*With* a reference standard, maybe, but not easy.
*Without* a reference standard, no.
Posted: Mon Jul 11, 2011 3:54 pm
by vishnu
I can use some DMA solution as ref std. can you explain the method please???
Posted: Mon Jul 11, 2011 10:01 pm
by tom jupille
I'll repeat what I posted earlier:
Posted: Tue Jul 12, 2011 8:08 am
by HW Mueller
There is also still that possible confusion about DMA and N-methylmethamine.
Posted: Tue Jul 12, 2011 2:43 pm
by DSP007
Hello Vishnu !
TLC in Benzene/CHCL3/Acetic acid mixture in cold and visualisation by Dragendorf reagent ?
Posted: Tue Jul 12, 2011 4:06 pm
by vishnu
Dear DSP007,
Thanks, but i cant get you. can you please explain???
Posted: Tue Jul 12, 2011 4:58 pm
by tlahren
Vishnu,
I believe this is what DSP007 is referring to:
http://www.erowid.org/archive/rhodium/p ... .ident.pdf
Or something similar. This is a research paper on TLC for amphetamine detection using Dragendorff Reagent. Also says how to prepare the reagent.
I think what Tom was getting at was making a fluorescence derivative and putting that on a TLC place and detecting it using a UV lamp or something of the sort. Please correct me if I'm off with that one Tom. This would probably work equally as well. In reality you will need to derivatize the amine to something that gives off light (necessary for visual ID for TLC).
Hope this helps get you on track.
Posted: Tue Jul 12, 2011 6:59 pm
by tom jupille
That is correct.
