35900D on Windows 95?
Posted: Tue Jul 05, 2011 7:40 pm
by rabidshark
Hey folks! I was wondering if anyone has documentation or recalls how to install a 35900D A/D Converter on a Windows 95 system. I'm trying a few things, but I've had little to no success as yet. Might be a driver issue or something, as I have none, but I'm sure someone here has a system with a working 35900D can give me a hand.
Thanks in advance!
-Adrian
Re: 35900D on Windows 95?
Posted: Wed Jul 06, 2011 4:17 am
by Consumer Products Guy
Yes, 35900D internal A/D will run fine with Windows 95, we have several systems doing just that. You need to use Configuration Editor to add the 35900D from the drop-down list, then check or "X" both the A and B boxes. You also NEED to run a remote from the A/D card to your "stack" or you won't record the signal. We have a few of the little instalaltion books for these. And of course a signal cable to your detector. Post your E-mail address and maybe I can scan this and E-mail. Post it as "abcd -at- yahoo dot com" form.
I have NOT been able to get the 35900D to work with Windows 2000 however, for those I use an external 35900E box.
Posted: Wed Jul 06, 2011 3:10 pm
by rabidshark
Thanks much!
adrsmith -at- mtu dawt edu
