FID hydrogen problem
Posted: Tue Jul 05, 2011 12:39 pm
Hello coleagues
I use shimadzu GC-17A v3 with Class VP 4.3 software and ss420x A/D bord.
I have problems with H2 flow of FID. When I download a method's parameters to the instrument hydrogen flow turns off. to obtain chormatogram I have to turn H2 on by hand and to reignite detector while autoinjector prepares to inject.
This happens since I changed the computer of the system. I installed and configured the software according to instructions and the same parameters of method I used when everything was ok. The problem occures on Win XP and VISTA, I tried both OS but this isn't the reason.
Gas pressure is within the limits, FID is turn ON both on GC and software. If I start a run from autoinjector by hand everything is ok, but when I start it from software- H2 turns off.
Please give some advises what to do...
thanks and greetings
Achkata
Achkata
