Metrohm 761 IC
Posted: Tue Jul 05, 2011 7:30 am
by ilawrence
I have a 761 Compact. I was wondering what is the version of IC Net software I
need to run on this instrument. Also can I use an external detector with
this instrument, (waters 410 RI), if so do I need an interface?
Thanks in advance
Re: Metrohm 761 IC
Posted: Tue Jul 05, 2011 2:34 pm
by ducadibovisio
Have a 761 compact too, I use IC Net 2.3 to run the instrument. Sorry I don't know if y can use the waters 410 coupled with it
Re: Metrohm 761 IC
Posted: Thu Jul 07, 2011 1:48 am
by remesquaddie
You can take the analog signal from the back of he 410 RI to your "computer" if it can take analog signals.
this instrument, (waters 410 RI), if so do I need an interface? Thanks you
for all your help.
Thanks in advance
Re: Metrohm 761 IC
Posted: Mon Jul 11, 2011 9:11 am
by Markus Laeubli, Metrohm
Dear ilawrence
Sorry to answer so late.
The latest software version is ICNet 2.3 SR6. you may download it fre of charge from the
Metrohm Software Center.
To connect an external detector you need the
771 IC Compact Interface.
Re: Metrohm 761 IC
Posted: Wed Jul 13, 2011 2:44 am
by ilawrence
Thanks Markus
