HP 1050 UV Detector.
Posted: Wed Jun 29, 2011 11:34 am
Hi all,
hope all is well... i have been using the same HP1050 for some time now and only until recently am getting a message on the UV detector saying "Low Illumination". Could a fault, as i started seeing the message shortly after moving, or do i need a new lamp for the detector. I would appreciate any info or feedback.
I am based in the UK, so if theres anyone reading this from the UK and can supply it would like to hear from you, or if you abroad and feel its something that can be shipped safely then id also like to hear from you.
Thanks for your time
Kind Regards
Dave
Kind Regards
Dave
