UPLC resolution (problem)
Posted: Mon Jun 27, 2011 8:29 pm
Hi everyone!
I have one question about the resolution...
We know, that the optimal resolution value for two separated peaks for different proteins has to be 1.5. That is well known for example HPLC columns, 15 cm long, that is filled with 5 μm size of the silica. But I also have UPLC column, 5 cm long, that is filled with 2,6 μm silica. I got perfect resolution between two narrow peaks in chromatogram, no tailing, the base line is reached between, but the resolution is only 0,96! How can I explain that? Is around 1.0 enough value for UPLC resolution?
Thanks a lot for the answer!
