interfacing photon multiplier tube with agilent 1100 system
Posted: Thu Jun 23, 2011 5:41 am
Hi all!
welcome to me!
I'm in the process of setting up a chemiluminescence detector on an agilent 1100 HPLC system. I am having some trouble understanding how it might interface.
The detector is basically a photon multiplier tube, with an amplifier, which outputs to an RS-232 serial port. I understand this to be a digital, rather than analouge signal.
So my question is, what is the best way to get a data series ultimately into Chemstation (or something like it - nice and automated 'cos I will have hundreds of samples).
The PMT comes with software which can collect data directly from the PMT (RS-232 or USB connection), and give me a data series which I can copy into excel. It would require a trigger signal to tell it when to start collecting data. Then I would have to find a way to get the data into software which will identify and integrate peaks for me - is there a way to get the data into chemstation??
The other option would be to connect the PMT to the RS232 port at back of the 1100, but I don't really understand what happens to the signal after that, or how to collect the data.
I would be very gald if someone would educate me on these matters, and if I'm asking ignorant questions. please be nice, I'm pretty green at this!!!
Thanks in advance!
welcome to me!
Thanks in advance!
