high pressure on agilent 1100
Posted: Thu Jun 16, 2011 12:59 pm
I've checked for older posts but can't seem to find a solution/suggestion.
We are running an Agilent 1100 and have tried to prime all 4 lines, but we're getting slowly climbing pressure on the system (no column attached) and we've put water, MeCN, buffer and various mixes down the lines indivudually and we manage to clear the pressure. If we try to put two lines on at once the pressure goes way up (>400bar) then one line that was previously clear will be blocked, then another one we've cleared will be blocked etc: There doesnt seem to be a pattern we can identify apart from lines going from clear to blocked!
We filter all our mobile phases, have cleaned all the lines and our column is working on another system so its not any of these either.
Would a problem with the actual pump or mixer valve cause very high pressure? Any tips on how to clean them or indeed investigate them in the "guts" of the machine without breaking it would be appreciated.
If any more information would help please ask any help is very welcome!
L x
L x
