Advantages and Disadvantages of Cartridge Columns?
Posted: Wed Jun 15, 2011 10:12 pm
I am looking into buying a Luna cartridge-column to analyse poly-phenolics in plant samples. Our lab is broke, so I want to make sure I'm getting something which will work. I chose it based on these two applications in the Phenomenex application library:
https://www.phenomenex.com/Application/ ... ion/Search
The column itself is here:
https://www.phenomenex.com/Products/Par ... tail/15617
The two applications are great and the column is cheap, so it seems perfect. However its a little "cartridge column" and I have never used one before. What's the +/- to this vs a more conventionally sized analytical column? It's so cheap I'm worried there is some downside I'm not seeing due to my inexperience. Also, it should be noted, that I intend to couple my system to an MS/MS to validate the identity of some of these compounds, how should that factor into my choice?
Thanks a lot for any advice.
