Page 1 of 2
conversion of mole % to weight %
Posted: Sun Jun 12, 2011 2:41 pm
by amrnasser87
how could i converte mole % to weight % for gas mixture using ideal gas law
example
gas mixture ( methane 10 mole % and argon 90 mole % )
pressure 2000 psi
volume 50 litre
if i want prepare this mixture using Gravimetric method what is the wight percent for each commponent in kg
Re: conversion of mole % to weight %
Posted: Sun Jun 12, 2011 3:06 pm
by Axar
Hi!
Sorry, but i can't understand why should we use ideal gas low?
We can calculate weight % without using volume %.
example:
Mathane's molar mass is 16 g/mol
Argon molar mass is 40 g/mol
Calculation:
weight % for methane = (10%*16 g/mol)/((10%*16g/mol)+(90%*40g/mol))
weight % for argon = (90%*40g/mol)/((10%*16g/mol)+(90%*40g/mol))
if I don't miss something in my calculations...
Ideal gas low is used for volume's calculation.
Posted: Mon Jun 13, 2011 4:04 pm
by JI2002
When working with gas standards, you either use units in v/v (ppbv, ppmv, %....) or units w/v (ug/m3, ug/L, mg/m3....).
Posted: Mon Jun 13, 2011 4:27 pm
by larkl
You can convert each to weight by multiplying the mol% by the mol. weight for each component. Then re-normalize to 100% and you'll have the weight percent.
There's probably some way to get there with the gas law, but I do it with the mol weight.
Posted: Tue Jun 14, 2011 8:11 am
by HW Mueller
The gas law has nothing to do with that, Axar gave the answer, why foul it up?
Posted: Tue Jun 14, 2011 8:54 am
by DSP007
Hello
Just has. In this case, and argon and methane behave as ideal gases (not liquefied). Accordingly, their volume concentration is constant. Accordingly, they can be counted by the ratio of molecular weights, if necessary - then we can give them volume and temperature to standard conditions.
Posted: Wed Jun 15, 2011 10:29 am
by HW Mueller
DSP007, ???
Posted: Wed Jun 15, 2011 2:51 pm
by amrnasser87
thanks to all replys
let me change the question , what about if the customer need the mixture in argon balance(i.e. solvent) instead of 90 % at 130 bar, so , how could i calculate the required weight of argon to reach that pressure with 10 mole % methane and 5mole% ehane in 50 L. volume
Regard
Amr
Posted: Thu Jun 16, 2011 8:03 am
by Peter Apps
100% - 10% - 5% = 85 %. Look up the density of argon; volume x density x % = weight needed.
Or is there some complication that I am overlooking ?
Posted: Thu Jun 16, 2011 9:55 am
by HW Mueller
I don“t follow this last question. You have a given 85 mol% argon, but want to use argon to adjust a certain pressure? Volume and temp. stay constant? Magic.
Posted: Thu Jun 16, 2011 11:28 am
by Axar
Also you can calculate it with ideal gas low with the way that DSP suggested.
I'll try to rephrase his post:
According to ideal gas low, mole% and volume% are same (at any pressure). Argon is almost ideal gas, so this way is accurate enough.
Posted: Thu Jun 16, 2011 11:53 am
by Peter Apps
Hi Axar
I am completely at a loss to understand how what you are suggesting differs from what I presented. The ideal gas law, crudely paraphrased, says that volume fraction = mole fraction. Molecular weight is constant. Once the gas is mixed and in a container, compressing it and heating or cooling it makes no difference to the mass fraction, mole fraction or volume fraction composition of what is in there. Even if some of it turns to liquid under pressure (which might be what is worrying the OP) as soon as you open the tap it will turn back to gas, with the same composition as you started with.
Posted: Thu Jun 16, 2011 11:57 am
by JI2002
You can do all the calculations you want and they are simple. I just don't understand the logic of calculating weight % for gases. The question is confusing. :?
Posted: Thu Jun 16, 2011 12:02 pm
by Axar
Hi Axar
Hi Peter!
You used density in your calculations, and DSP don't. Your way is more accurate, but needs more information.
Posted: Thu Jun 16, 2011 1:15 pm
by Peter Apps
Hi Axar
Hi Peter!
So substituting we go from: "100% - 10% - 5% = 85 %. Look up the density of argon; volume x density x % = weight needed."
To:
100% - 10% - 5% = 85 %. Look up the molecular weight of argon; volume / 22.4l x molecular weight x % = weight needed.
Kind of simialr, no ?
