Problems with CO2 on Alltech's CTR I column
Posted: Fri Mar 18, 2005 10:00 pm
Greetings,
I am runing CO2 analysis on Alltech's CTR I column. The CO2 is tailing and there are no leaks in the system. Alltech says that the CO2 is have a chemical reaction with the porous polymer column and that is why its not coming completely off. Has anyone experienced this or been able to solve this problem??
Thank you,
Shelley
Thank you,
Shelley
