Welding weldment on injection port...
Posted: Thu Jun 09, 2011 6:13 pm
by chemwipe
Hello all-
After doing routine maintenance on my 5890, I noticed the pressure wasn't holding. I checked everything as far as tightness, and upon leak checking, found a leak here:
It must be some kind of hairline crack, I can't see it. Can this be welded?
John
Re: Welding weldment on injection port...
Posted: Thu Jun 09, 2011 8:32 pm
by JGK
Probably not, you will save time effort and probably money by just purchasing a new component
Posted: Fri Jun 10, 2011 7:44 am
by Peter Apps
Welded, no. Silver soldering would be worth a shot, what do you have to lose ?, it is unusable as it is. If you are not comfortable with silver soldering then take it to a jeweler, or a hobby jewellery maker, they will have the kit and the skills. Good luck.
As an extra note, this tubing arrangement was one of the less inspired pieces of GC design.
Posted: Fri Jun 10, 2011 8:02 pm
by Consumer Products Guy
I agree silver soldering would be a decent try. See Ace Hardware or Sears, they've stocked kits of this, I've used them (but not for GC).
I think our shop (about 10 years ago) silver-soldered up the two holes in an Agilent SS inlet liner for a special application for us, and it's held up.
