Selective extraction/precipitation targeted peptide
Posted: Sun May 29, 2011 8:38 pm
I have what seems like it should be a relatively straight forward MS task- to ID a peptide (we believe exists) in insect heads. This ligand is > 80 aa and well retained on RP as well as cation exchange columns. pI near 8.
Main concerns are to minimize proteolytic degredation, and to use selective solubility to enrich sample. The peptide is soluble and extractable in 90/10 MeCN/HOAc, so I imagine this excludes most proteins much larger than 20 KDa. Also seems proteases, if soluble, ought to be inactive in such a solvent composition. However, lipid material is also extracted. This lipid material co-eluted (or escaped) SPE and fouled the prep C4 column.
I am considering liquid/liquid extraction of the MeCN/HOAc sup with hexane, or else, adding something miscible, such as DCM (acetone? MeOtBu?), hoping my target peptide will eventually precipitate.
Any rough idea as to the amount of DCM I may need to add (1-2, 10 volums?) before I should give up on precipitation, and add hexane and try liquid/liquid extraction?
