application method for Cannabinoids by GCMS
Posted: Sun May 29, 2011 5:12 pm
by andros
We are using Shimadzu GCMS2010 to measure cannabinoids. Does anybody has the analytical instrument method to compare with our method since our results are not so good.
Re: application method for Cannabinoids by GCMS
Posted: Sun May 29, 2011 5:29 pm
by Don_Hilton
Are you trying to follow a published method? If so what kind of problem are you having? The make of mass spectrometer should not be an issue unless you are tring to use a quadropole instrument where something like a sector instrument is requried.
