Perkin Elmer error codes
Posted: Fri May 27, 2011 2:35 pm
by AStav
Hi all.
Not sure if this is a FAQ or previously asked, but it didn't appear so in a key terms search.
I have a couple of Perkin Elmer error codes appearing (time to time) and usually self diagnose and fix. However, to speed things up, is there a published table of PE error codes anywhere?
I haven't come across any the usual publish domains, guide, specs or web searches.
Many thanks.
AlStav
Re: Perkin Elmer error codes
Posted: Fri May 27, 2011 6:40 pm
by alemaggot
Have you see on the totalchrome user guide?
Posted: Tue May 31, 2011 11:45 am
by AStav
Nothing noted.
Had a look through, nothing relating to the error codes seen (or my skim reading is skimming too fast).
Posted: Wed Jun 01, 2011 6:55 pm
by alemaggot
If you don't found nothing, you ask directly to your Technical if he have what you search... or not?
