GCMS noisy background
Posted: Thu May 26, 2011 7:02 am
Hi all
Im doing some method development for our GCMS system and was following the literature reference to set our MS settings. The literature was using the Agilents GCMS where as ours is Shimadzu QP2010 plus GCMS
and The results was a very noisy background as shown
The peak shown here is my target compound
Since I am not very familiar with MS setups any tips which parameters should I tweak first to reduce the noise levels? the current MS setting for the above is:
Ion Source Temp 250°C
Interface: 300°C
Detector gain mode: Relative
Detector gain: 0.000kV
Threshold: 1000
Acquisiton mode: Scan
Event time: 0.5 sec
scan speed: 1250
Start m/z: 30
End m/z: 580
Interface: 300°C
Threshold: 1000
Event time: 0.5 sec
scan speed: 1250
Start m/z: 30
End m/z: 580
