Mobile phase buffers for LC/MS
Posted: Wed May 25, 2011 10:45 pm
What mobile phases are people using other than ammonium acetate, acetic acid, and formic acid that are compatible with LC/MS?
What do you use if you want a pH that's in between acid and neutral?
