Ghost Peak on a TCD of HP Series II
Posted: Tue May 24, 2011 7:24 pm
Carrier gas: Helium
Column: Carboxene 1006
Oven: 23 C
Inj; 230 C
Det: 230 C
Problem: I have been receiving a ghost peak every 10 mins or so that only occurs after the first sample of the day is introduced. it still shows up if I do a blank run in the middle of the day and it shows up pretty consistently, though sometimes the interval changes. I have tried changing my injector and detector settings with no success. Any advice you guys have would be great. I also admit that my experience with GCs is quite limited so if someone has a resource they recommend that covers alot of the more technical aspects of installing and maintaining pieces of a GC (ie how to check carrier gas flow and installing a detector) it would be greatly appreciated.
Oven: 23 C
Inj; 230 C
Det: 230 C
