P-nitrophenol sodium determination
Posted: Tue May 24, 2011 7:11 am
Good afternoon:
Anyone of you know how to analyse p-nitrophenol sodium in pesticide by HPLC method?
Previously i was using Column C18, together with mobile phase (water 60%:methanol 40%,adjusted to pH 3.0 by phosphoric acid). But, the method seem like unstable and i cant even get a "sharp" peak. Somemore, i also cant find a suitable internal standard because most of the IS cant dissolve in water.
Thanks.
Thanks.
