Having been summoned, I emerge from the lamp...
Concerning hydrophobic effects, there's charged coatings and then there's charged coatings. First, take a look at my paper in J. Chromatogr. 359 (1986) 85. This demonstrates that a single methylene group makes a substantial difference in the hydrophobic character of a coating in the hydrophobic interaction chromatography (HIC) mode. That means methyl- vs. ethyl- vs. propyl. Same goes for an ion-exchange material. That's why we make our SCX material, PolySULFOETHYL A, with a sulfoethyl- ligand instead of the sulfopropyl- (= SP) ligand used by nearly everyone else. It makes a difference. In A. Holm et. al., Anal. Bioanal. Chem. 382 (2005) 751, they compared four different SCX materials regarding degree of hydrophobic interaction with the peptide angiotensin II. See pg. 755; 10% ACN eliminated any vestige of hydrophobic interaction in their test when using PolySULFOETHYL A. It took 20-25% to do so with the other three SCX materials.
There's been a number of papers in the literature recently extolling the benefits of using a fairly hydrophobic material in the HILIC mode, implying that you can get hydrophobic and hydrophilic interactions operating simultaneously to effect a separation you can't get any other way. Retention of solutes as a function of % organic solvent is a U-shaped curve; the hydrophobic interactions almost always are reduced to zero or close to zero before you get to a level of organic solvent where the hydrophilic interactions start to become significant. Result: The bottom of the U is flat, not sharp, with the two regions separated widely. If a material has no significant amount of hydrophobic character, then the curve of retention is a backwards L shape, not a U.
DJ: The application you cited on May 31st was my work from 1996, performed with some peptides from your lab at U. Nevada-Reno. This synthetic peptide was an unholy mixture of failure sequences, making it an ideal standard for testing the selectivity of the experimental method in question. This was the uncharging of a weak cation-exchange (WCX) material with a decreasing pH gradient, leading peptides to elute in a totally volatile solvent from an ion-exchanger (this method has been revived for top-down proteomics, most recently with histones). If you want the full poster, download it from the Literature section of our web site (
www.polylc.com); it's the ISPPP 1996 poster. I did note the novelty of the Arg- deletion peptide eluting later than the version with all of the Arg residues. However, there was ample opportunity for internal salt bonds. Also, per the paper that Kostas posted the link to in his posting of May 27, not all the charged residues in a peptide have access simultaneously to a stationary phase surface. That means it's unclear how much effect putting in or taking out a particular arginine should have. If taking one out results in the peptide assuming a conformation in which more of the basic residues have access to the surface than was the case before, then this could provide a rationale for an increase in retention. All in all, it's a complicated scenario. If you're trying to build a model for interactions in chromatography for purposes of prediction of retention times, start with simple standards first.
