High Temperature GPC column
Posted: Fri May 20, 2011 6:05 pm
by push
Looking for mixed mode High Temperature (150C) GPC column? Please advise.
Re: High Temperature GPC column
Posted: Fri May 20, 2011 6:40 pm
by unmgvar
the mostly relevant detaisl to know is the nature of your samples?
and the MW range you are interested to work at
viscotek/malvern have a high temp GPC system, so they also have the columns to work with it
i know also polyanalytik that has high temp GPC columns
both companies have mixed beds columns
is this for polyolefins?
from experience if you have 2 very different narrow species then you can use the mixed beds, but if you expect several broad compounds, then it is best to use several columns in series, each specific for the range of each compound, you results will be far mor precise
Posted: Fri May 27, 2011 7:13 am
by push
Thank you, unmgvar,
Yes, it is for pollyolefines. Which set of columns do you recommend to cover a range 500 - 1000000 Da?
Posted: Fri May 27, 2011 10:51 am
by Gerhard Kratz
What is the max temperature you want to operate? I agree with unmgvar, maybe a series of 3 columns you will end up. Above 145°C are also HT columns available, also mixed bed columns. Have a look also at Waters, Phenomenex, Shodex and Jordi. Good luck.
