peak naming and no calibration
Posted: Thu May 19, 2011 8:19 pm
Hi all,
Our lab is still undergoing our transformation from Chemstation to Empower 2. I have figured out a lot of ways to get what I need from Chemstation. I am sure Empower2 can do the same things even better (although some would argue this point!), so I figure I would ask the group a couple questions.
The majority of our HPLC assays do not require a calibration curve to be generated. It is a lot of cation exchange and SEC of biologics (large molecule) and we simply run a system suitability and our samples, and calculate area%. We group peaks together, too. So in SEC we would group all the aggregates (higher molecular weight) together, and the fragments together (lower molecular weight). In Chemstation, I was able to name multiple peaks with the same name. How do I do this in Empower2? I thought there was an easy way to do this using groups. I have no desire to name each peak as Peak 1, Peak 2, etc.
In addition, because there is no calibration needed, are there some steps i can just simply skip over to get right into processing my run? I was hoping some one could guide me to the most elegant way of processing data using multiple processing methods (not all samples will integrate similarly as some are stressed stability samples)?
Also, if anyone out there has experiencing integrating biological samples (not the cool, sharp, small-molecule peaks!), I would love some tips. These peaks are broad and have subtle shoulders sometimes.
Thanks!!
Thanks!!
