When we analysed samples using both detectors, I am able to batch process the MS part of the data, but am unable to find any function to do so for the UV part of the data.
Does anyone know how to get MassLynx or QuanLynx to batch process the data obtained using a UV detector and have the peak areas exported to an excel file?
In addition, how do I get MassLynx to display chromatograms from 2 different files in the same window?
I used to be able to do so as a default, such that traces from 2 different files will appear in a single window. I am not too sure what settings has been reset after we re-start the system. Now, traces from 2 different files will appear in 2 different windows. It gets frustrating when I am trying to view multiple files together and kept having to click on different windows.
Thanks in advance!
