Plot area for ChemStation A.09.03
Posted: Thu May 19, 2011 2:39 pm
by Cherrypye
I have ChemStation A.09.03 and need to darken the chromatograph. When it prints you can barely see it. Can it be adjusted some how?
Re: Plot area for ChemStation A.09.03
Posted: Thu May 19, 2011 5:52 pm
by Blazer
I might look at your printer settings first. Is the entire report page too light? Or is it just the chromatogram?
Posted: Thu May 19, 2011 6:10 pm
by dblux_
viewtopic.php?f=4&t=16245&start=0
Is this what you need ?
Posted: Thu May 19, 2011 6:19 pm
by Consumer Products Guy
See above link, was my issue then.
Also:
Common Agilent ChemStation PCS Colors
0 255 0 green
0 255 255 light blue
255 0 255 purple
0 0 128 dark purple
255 255 255 yellow
0 0 255 blue
0 0 0 black
255 255 255 white
Chromatography traces darker for printing on Laserjet printers:
Exit ChemStations, use Configuration Editor, Configure colors, to change Signal 1 from default blue (0 0 255) to dark purple (0 0 128), then Save the configuration. This will print darker on a black Laserjet printer, especially when the printer is set up to print 2 or 4 sheets to a page of paper.
This changes (in the Windows\win.ini file) the line in the [PCS,1] section that had been DEChrom1=0 0 255 to DEChrom1=0 0 128. So this change can also be made in the Windows\win.ini file directly, and saved, and would then become active next time the ChemStation is initialized.
Posted: Thu May 19, 2011 7:17 pm
by Cherrypye
Thank you for the information. I adjusted my printer to the most advanced setting and still no change. I will try to change the color next.
