"jagged" peptide peaks
Posted: Tue May 17, 2011 1:10 am
Hi all,
I am developing an LC method for a peptide with 20 AAs. I've been told there are 5 arg/lys/his
My problem is that the peak is looks jagged and I would say that it must have several coeluting peaks. I have tried different types of chromatography and columns to try to resolve this:
C4/C12/C18 columns with ACN/ 0.1% TFA in various combinations/gradients
SCX pH 2.5 early eluting, poorly retained
IP with hexane sulfonate on C18,
I have tried diluting the samples in water, 6M urea, 0.1% TFA with similar results.
all of the chromatograms suggest several coeluting peaks (4 or more).
Is it possible that this is an artifact? (eg. non-homogeneous charge states? or some kind of isomerism?)
If it is an artifact, what else could I try to resolve this? The chromatographies seem reproducible, so I'm thinking that perhaps the sample prep may be the real issue...
Suggestions?
cheers
Suggestions?
cheers
