Standard Calibration Curve
Posted: Mon May 16, 2011 6:17 pm
Dear All,
I would like to prepare standard calibration curve for pesticide analysis.
Range are 0.01 , 0.1, 2 and 5 ppm.
I have 10 ppm OP mix standard about 5 ml.
I wanna prepare just 1 ml each of these concentration.
What is differences between make up volume and mix volumes??( I have not very small volumetric flask, just 10 ml I have, I don't want to and no need to prepare 10 ml, for me 1 ml is enough)
So how should I prepare??
Can I prepare by mixing, I meant mix the standard solution + solvent??
eg. I want to prepare 1 ppm standard 1 ml from 10 ppm stock.
C1V1=C2V2
1ppm x 1ml = 10 ppm x V2
V2 = 1ppm x 1ml /10 ppm
V2 = 0.1 ml = 100 uL
So can I take 100 uL of 10 ppm standard into the vial and add 900 uL of solvent??
Is this same with make up volume??
I am confusing
, please help me.
K.M.P
C1V1=C2V2
I am confusing
K.M.P
