It's urgent! MS's intensity
Posted: Thu May 12, 2011 4:39 pm
Dear all,
I'm using LCMS system for analyzing charantin (extracted form bitter melon). i always have problems with MS system because charantin's intensity decreased after a short time using. Before running, i infused the calibrant directly into the source to confirm the intensity. it's intensity was really high if i had washed the spray shield with pure water by LC pump (flow rate 0.5ml/min). I saw the water droplet drop from the spray shield look like a rain drop. After washing, the intensity of the calibrant increase pretty high, but it decrease if i keep infusing the calibrant until the calibrant was run out of.
The intensity increase again if i wash the spray shield with LC pump.
i don't know what happened with it! It's desperate if i don't know why
! Please help me! I need all your helps!
