MIBK method for Shimadzu 2014 GC
Posted: Sun May 01, 2011 7:36 pm
Hi everyone,
I am a new learner. I did some experiments with Toluene and now I need to find best temperature program for MIBK. Actually first I tried to use the same method, that I used for toluene, for MIBK but it did not work. Finally I tried to use another method which is injection 90 C, Column 60 C (Rate 0) then 190 C(Rate 20) and finally 225 C(Rate 50) 1.5 min, Detector is 225 C.
Split mode 20.0
Pressure 40.4 kPa
19.4 mL/min
Clolumn Flow 0.78 mL/min
24.5 cm/sec Linear velocity and 3 mL/min purge flow
Column Length 15m (capillary)
Inner Diam 0.25 mm
Film Thickness 0.25 um
I am not sure what I am doing wrong, and If you can suggest me, I will really glad. In Chromatogram, I saw more than one peak.
Thanks in advance.
Osman
Split mode 20.0
Pressure 40.4 kPa
19.4 mL/min
Inner Diam 0.25 mm
Thanks in advance.
Osman
