pls help! The LC-MS suddenly stop running with errow remind
Posted: Sat Apr 30, 2011 7:16 pm
Hi all,
I am quite new to LC-MS. Previously another person in the lab was the main user of the instrument, so I just put my samples in and did not need to worry.
But now he left and the many problems coming out.
The biggest problem is the suddenly stop running problem. It would tell me there were errors. Then I checked the logbook. The error was always "the instrument is sending more spectra than the software can accept".
If I shutdown the software and restart it, sometimes it would go on running. But after several samples, the same error coming out again.
At the same time, I found the retention time was increasing in different runs; the baseline was rising and noisy.
I thought it might be some residue in the ion source. So I wiped the spray chamber with 50% MeOH and sonicate the spray shield in 50% MeOH.
The baseline looked better after each clean.
But the problem was still there.
Can anyone give me some advice?
Looking forward to your kindly reply!
Please, excuse my poor English.
