FID channel to high
Posted: Wed Apr 27, 2011 8:56 am
by kartikago
Hi, i'm use GCmobile2 from energy support. i have problem with FID channel. when i ignation, FID channel show almost 272000 micro volt. So i can't analysis the gas. Before the problem usually that FID channel show 87564 micro volt. Can any one to help me.
Re: FID channel to high
Posted: Wed Apr 27, 2011 11:36 am
by Don_Hilton
Check over some of the posts from the past few weeks there have been others with similar problems. The first question that I have on hearing of this problem is what is the quality of gas you are using for carrier, FID fuel, and air? Hydrocarbon background in any of these gasses will raise the background. Second question I have is what are you using for plumbing? Connections with tubing that has been contaminated with oil ( or not properly cleaned after manufacturing) can result in the addition of hydrocarbons to the gas stream. And regulators: the diaphram material is important. Rubber or plastic can add organic compund to the gas stream. (GC vendors typicall specify stainless steel diaphrams in regulators.)
Posted: Wed Apr 27, 2011 1:17 pm
by DSP007
Hello. When you incinerate 87 mV when you incinerate, or in the work process? Stable potential (value)? The most likely problems have regards Don Hilton.
I have not seen GC2. If he is such a plan - you might just happen to touch attenuation resister.
http://www.anchem.ru/forum/read.asp?id= ... cordnum=20
