FDA - Integration Algorithm Consistency
Posted: Sat Apr 23, 2011 12:34 am
Our HPLC data isn't audited by the FDA, but I would like to get into the habit of doing everything possible "by the book." So, does the FDA prefer to see the same algorithm used for all samples run of the same analyte regardless of the time they were run? For example: should all samples tested in order to determine the amount of caffeine in them on January 1, 2011 use the same algorithm as those samples tested for the caffeine content run on June 1, 2011?
I would think that as a column ages the integration would change accordingly in order to properly integrate the peaks, but it could be argued that if the column ages to the point that you have to change the algorithm then you need to replace the column.
When I say "integration algorithm" what I am referring to is - on our Perkin Elmer HPLC (Chromera) system at least- is that integration is determined by 3 numbers: bunching factor, area threshold, and noise threshold (as this is the only HPLC software system that I have operated I have no idea if this is consistent across all machines - once again, my guess would be that it's pretty similar but with the slight variations that come with various companies but since I have virtually zero experience I'll refrain from making assumptions).
Thanks for all the help!
