Jagged IC Peaks
Posted: Thu Apr 21, 2011 8:22 pm
I'm using a Dionex Ion Chromatography system and have just started having jagged sulfate peaks. I'm using their Seven anion standard and an AS4A column with carbonate eluent. I've been using this system for years and years and have never seen this. I've swapped out the column and that made no difference. Nor did new eluent and standard prep. I'm really curious as to why it's only on the 7th peak? Retention time and % Recovery are consistent. Any suggestions?
