Dumb question about software for HP 5890 Series II
Posted: Thu Apr 21, 2011 5:26 am
by Thor2202
I've been out of the lab for a while, and the last rig I ran was a 6890, so- sorry if this is a basic question.
If I'm buying a refurbed 5890 series II for the lab, what are my software options? Are there any freeware packages out there?
Re: Dumb question about software for HP 5890 Series II
Posted: Thu Apr 21, 2011 12:00 pm
by akribis2
Unfortunately the 5890 is a rather old machine (as i have thought about purchasing one before), and with that, the software for the readouts/analytical data I would presume be hard to get hold of, I am still doing research for the 5890 II I will update you if I come across a software solution for you!
Best of luck
Used Lab Equipment
Posted: Thu Apr 21, 2011 7:08 pm
by Consumer Products Guy
If that 5890 is already computerized (e.g. has circuit boards in the module), it should've come with a license number, software, and computer.
We use Win95 or Win2000 with our 5890 units, and Agilent A.06.03 through A.09.01
Posted: Mon Apr 25, 2011 3:42 am
by AICMM
Thor2202,
The fundamental question that helps resolve your question is if all of your components of interest are going to be at basically the same level. If that is the case, you can use the analog out function and the range function of the 5890 to report to a wide range of data systems that will allow you to manipulate the data electronically. If your components of interest are at widely different concentrations, you will have a much harder time getting everything on scale with the 5890 analog out and you should really look at an integrated acquisition package like Chemstation. So which is it?
Best regards,
AICMM
Posted: Tue May 03, 2011 9:10 pm
by ivanvins
You could check our Clarity software
http://www.dataapex.com/product.php?id= ... nt5890.php
Ivan Vins
www.dataapex.com
Posted: Wed May 04, 2011 12:28 am
by Karen01
2 years ago (before my job went away) I had 2 5890s running on Empower 2. Don't know if Empower 3 supports them.
- Karen
Posted: Fri May 06, 2011 3:53 pm
by antonk
Also have a look to our UniChrom software
http://www.unichrom.com/hpx890/hpx890e.shtml
Demo version acquisition works for 3 min.
