lc-ms s-adenosylhomocysteine and s-adenosylmethionine
Posted: Tue Apr 19, 2011 4:57 pm
by shahgholi
I am interested in LC-MS detection of SAH and SAM in brain tissue at nmolar levels. I am following a paper where this is achieved using phenylboronic acid SPE cartridges for extraction followed with LC using a 2 x 100 Waters Symmetry shield column with water, methanol, 0.02% acetic acid as solvents. SAM and SAH elute at about ~ 0.5% methanol. In this paper SAH and SAM are detected down to nM levels (20 uL injection of 5 nM solution) and the calibration curve is linear up to ~800 nM. Flow into the source is split four-fold.
I am using a TSS uplc column, 2.0 x 100 mm, and similar solvents and gradients. SAM peak looks broad but symmetrically tailing. SAH peak is terribly broad. Sensitivity is very bad.
I switched to an old 1 x 150 mm column and noticed that the SAH peak was better but still terrible.
Any suggestions with this analysis is greatly appreciated.
Mona
Re: lc-ms s-adenosylhomocysteine and s-adenosylmethionine
Posted: Thu Apr 21, 2011 9:36 pm
by shahgholi
Mona
Just wanted to mention that my analyses are working quite well now. Three things helped: switching from TSS column to a Symmetry BEH, adding some TFA to the sample, modifying source conditions (a lot hotter) on the ESI source. Thanks to those who read the post.
