Poor precision only affects one of the two peaks of interest
Posted: Thu Apr 07, 2011 7:40 pm
I've come across an interesting issue in which I am analyzing 2 peaks, which have a method specification of < 1.5% RSD by area and one of the peaks passes the specification and the other does not. Initially, the earlier of the 2 peaks (peak A) was failing the RSD spec. The method is a gradient which ramps immediately upon injection and uses a PDA from 200-400nm as well as monitoring 230 and 308 nm.
After looking thru the system and finding no obvious problems, I ran a calibration standard (which uses iscratic conditions) and the RSD result was 0.3%, well below our in-house calibration spec of < 1.0% RSD.
With this in mind, I ran the test in question using the method conditions and solvents/solutions and the specification was not met. I also ran the method isocratically since the calibration standard passed the specification under isocratic conditions. Only this time, Peak B (the later peak) did not meet the spec.
If it is an injector problem then logic tells me that both peaks would be affected.
My question: Why is precision poor for only one analyte in the chromatogram and not the other? Is this a system issue or do the analytes not 'like' this system? Furthermore, the analysis in question was moved to another LC and everything worked fine. I am stumped.
Any insight would be much appreciated.
Chris
Chris
