CO2 causing negative peak
Posted: Wed Apr 06, 2011 6:08 pm
I have a question about the CO2 response I am getting on my ECD. A little background about my system: I am running an ambient air sample through a Porapak Q column followed by a molecular sieve 5A column. The ECD is running at 340C.
The question I have is when I run my sample using N2 carrier gas, I see a small negative peak when CO2 elutes. When I add a CO2 dopant to the N2 carrier stream, the size of this negative CO2 peak increases. However, when I run the same system with 5% methane/argon carrier gas, there is no CO2 peak. I have determined that this peak is a result of ambient CO2 because when I scrub the air sample using ascarite, the negative peak disappears. The CO2 dopant is added as a makeup gas and only mixes with the N2 carrier gas right before the detector. I have tried purifying the N2 gas with a hot gas getter but there is no difference so I do not think it is a purity issue.
Can anyone help me figure out what's going on and why the different carrier gases cause different responses? I am trying to eliminate this negative CO2 peak when using N2 carrier gas.
Thanks for all you help!
Anita
Anita
