problem with the compond decomposition
Posted: Wed Mar 09, 2005 3:32 pm
The problem with the compound decomposition
I hope somebody could give me a help. Now I am using GC-FID to test the one compound purity. But I found the problem:
The compound boiling point is 102 C. it is very easy to decompose to other two compounds.
recently the method was set as following:
Initial rate temp wait
50 3.0
15 150 0
30 220 0
Inject port temp 105C. detect port temp 150C
Split Ratio is 46:1,
But at this condition, still small parts of compound had been decomposed.
50 3.0
15 150 0
30 220 0
