Guard column leaking packing material
Posted: Tue Apr 05, 2011 3:50 am
I'm running some standard semi-preparative reversed phase HPLC and am having lots of trouble with my guard columns.
I'm using a Shimazu semi-prepartive guard cartridge holder, containing a Sunrise C-18 cartridge, attached to a 250 x 10 mm C-18 column. If the pressure gets too high, the cartridge becomes deformed and the C-18 packing material starts leaking out, blocking the stainless steel tubing and head of the column proper. This causes another pressure spike, causing more leaking, etc. Even relatively low pressures (~150 bar) will cause this leakage.
I have replaced the leaking cartridge, only for the same problem to occur again with the new guard cartridge. I have one remaining but am reluctant to try it until I know what the problem is.
Has anyone else observed similar problems? Should guard cartridges be able to handle high pressures (300+ bar)? Is it possible I might have got a faulty batch? Any help would be most appreciated.
