Macro program for Agilent Chemstation
Posted: Fri Apr 01, 2011 4:21 pm
by JI2002
Hello all,
Can anybody provide a Macro program to print injection logs? This is Agilent MS ChemStation version E.02.00.493. Thanks a lot.
Re: Macro program for Agilent Chemstation
Posted: Mon Apr 04, 2011 4:06 pm
by chemstation
If you go to
http://www.chemuserworld.com/forum/view ... php?tid=14
and download the excel spread sheet, this will create a list of injections, and the output can be adjusted.
N.B. Macros in Excel need to be enabled for the spread sheet to work (security setting tab).
you need to go into the xxx.d folder and double click on the data.ms file, the spread sheet will generate the rest.
You need to have MS Excel installed on the PC, or map the data directory to a PC with MS excel installed on it. (MS ExcelViewer will not run the VBA script.)
Alex
Posted: Tue Apr 05, 2011 12:46 pm
by JI2002
Thank you for your reply. It works very well.
